08-22-2013 01:05 AM
I want to poll and verify the state of NVRAM in C6509 devices.
Because the issue of "Configuration lost" after device reloads were observed.
I thought of proactively monitoring the state of device NVRAM.
Which MIB and OID will help me in monitoring the state of NVRAM?
08-23-2013 04:15 AM
Hi Raj,
1.3.6.1.4.1.9.5.1.1.67 sysStatus OBJECT-TYPE SYNTAX INTEGER { other(1), -- none of the following ok(2), -- status ok minorFault(3), -- minor problem majorFault(4) -- major problem } MAX-ACCESS read-only STATUS current DESCRIPTION "The operational status of the system." ::= { systemGrp 67 }
I just test this OID , it is working..
I hope this will help
Afroz
08-28-2013 08:20 AM
Hi Afroj,
When checked with MIB browser on C6509, i got "ok" as response.
Is this response indicates the overall system status or only the status of NVRAM.
08-28-2013 08:30 AM
Hi Raj,
This is The operational status of the system. I mean "over all System status.
afroj
08-28-2013 08:40 AM
Thanks Ahmad for the clarification.
However, is it possible to poll and check only the state of NVARM in C6509?
