LMS 4.0 Performance poller Threshold Issue
I am trying to configure a performance poller threshold for CPU utilisation (5minrev).
While doing so, I am facing following issues:
1. When the poller template (CPU utilization) is selected, no MIB variable is visible for further configuration.
2. In the instance selector option, I am not able to see and select the devices to which this threshold applies.
Presently all LMS management functions are enabled except the IP SLA performance management.
Rajmohan R
AFROJ AHMAD
Hi Rajmohan,
Are you getting any other Error under HUM  (Monitor >Performance ) ?
If no errors,Try the following steps , I hope this will help:
Steps 1:
+ Stop the Daemon Manager
net stop crmdmgtd
Step2:
+Go to  NMSROOT\CSCOpx\databases\upm ( look for upm.log  if Exist delete
or you can take a backup as well)
Step 3: +on Command Prompt Browse to the above Directory (NMSROOT\CSCOpx\databases\upm) > dbsrv10.exe -f upm.db
Step 4: +Start the Daemon Manager : net start crmdmgtd
wait for 10-15 mins and then try to configure the Threshold and see how it works!!
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
Hi Rajmohan,
Steps 1:
net stop crmdmgtd
Step2:
Afroz
Sorry, I missed to mention that LMS is installed over solaris.
Notwithstanding, I will try to carry out the suggested steps equivalent in Solaris.
Rajmohan R
Follow the below thread , it will help
https://supportforums.cisco.com/docs/DOC-8796
Afroz
Thank you.
I am now able to configured thresholds for poller and able to select devices/instances as well.
Rajmohan R
