LMS 4.0 synchronisation
sajanpainel
Hi all,
I have two LMS servers which are used to manage the same network. The requirement is to have two independent LMS platforms. But i want to synchronies the LMS configuration database/settings between these two servers. I.e. if are changing the inventory in one of the LMS same information should be available in second one. The changes applied to particular LMS must be synchronized to the second server like
1) User roles
2) Inventory changes
3) Jobs
4) Reports
5) collectors etc
How we can configure this ?
Michel Hegeraat
Level 7
Level 7
I think backup - restore is the easiest solution
Cheers,
Michel
Any script available to sync between two database tables ?
I'm not aware of such a script, but there is an High Availability solution available from cisco.
Since the underlying products were not designed to run in a High Availability way it uses 'other' ways to sync the disks of the 2 servers.
Anyway the backup is a good start of all the data you need to sync in terms of databases and files.
Cheers,
Michel
