LMS 4.0 Syslog messages from ACS 5.0
alex.dersch
Level 4
Level 4
i've added a Cisco ACS as device to my LMS. I configured the ACS to send syslog messages to the LMS server and i can see them in the syslog file. Unfortunatly it seemes the messages are not processed and i can not see the in the syslog report.
any ideas?
thanks & regards
alex
Joe Clarke
No, the ACS syslog messages are not supported by LMS.  The ACS is not a fully supported device by LMS Inventory and Config.
So it means i have to provide another syslog server for my ACS logs?
regards
alex
You can use LMS as your syslog server, but you will have to mine the messages from the syslog.log directly.  They will not be added to the LMS database.
