Apache web server not start
Hi. I had to reload my server with 2008 server R2 for a maintenance. but now apache web server on my LMS 4.0 no start. I tried stop and restart daemon manager but nothing. apache is stoped.
AFROJ AHMAD
Hi ,
Try the below steps and see how it works :
On the command Prompt run this commad to check the Dependency of the Apache :
C:\PROGRA~2\CSCOpx\MDC\Apache\bin>pdreg -l Apache
         Process      = Apache
         Path         = C:\PROGRA~2\CSCOpx\MDC\Apache\bin\Apache.exe
         Flags        = -d C:\PROGRA~2\CSCOpx\MDC\Apache -D SSL
         Startup      = y
         Dependencies = Tomcat
Now Unregister the Apache with below commad :
pdreg -u Apache
To Registered the Apache:
Note :You need to check the Apache.exe location  ,so anyone of the below  will work for you  :
C:\PROGRA~2\CSCOpx\MDC\Apache\bin>pdreg -r Apache -e "C:\PROGRA~2\CSCOpx\MDC\Apache\bin\Apache.exe" -f "-d C:\PROGRA~2\CSCOpx\MDC\Apache -D SSL" -d Tomcat
(used your NMSROOT Location )
C:\PROGRA~2\CSCOpx\MDC\Apache\bin>pdreg -r Apache -e "C:\PROGRA~2\CSCOpx\MDC\Apache\Apache.exe" -f "-d C:\PROGRA~2\CSCOpx\MDC\Apache -D SSL" -d Tomcat
Now re-check the Apache Registration :
        Process      = Apache
        Startup      = y
Once above is done try to Restart the Apache and check how it works !!
Thanks--
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
