LMS 4.1.1 ANIServer Failed to start
Derek Morin
after some upgrades my ani server will not properly start.
C:\PROGRA~2\CSCOpx\bin>pdshow ANIServer
        Process= ANIServer
        State  = Failed to run
        Pid    = 0
        RC     = -2
        Signo  = 1073741822
        Start  = N/A
        Stop   = 5/10/2012 11:57:07 AM
        Core   = Not applicable
        Info   = Application failed or was registered incorrectly.
here is the begining of the log
2012/05/10 11:56:14 main ani ERROR ServiceModule: Failed to instantiate com.cisco.nm.ani.server.dfmpoller.NoServiceModule
2012/05/10 11:56:14 main ani MESSAGE DBConnection: Created new Database connection [hashCode = 19461870]
2012/05/10 11:56:15 main ani MESSAGE PartialSMFCommit: Partial Commit is enabled for DataCollection
log4j:WARN No appenders could be found for logger (com.cisco.nm.cmf.portal.ServerPortlet).
log4j:WARN Please initialize the log4j system properly.
The DCR port  =443
inthe portal adaptor
[Thu May 10 11:56:21 EDT 2012] INFO   [CMICLogger : info]  : com.cisco.nm.cmf.cmic.uii.action.CMICInteractor Making RPC call to import templates on PPCISCOWORKS:443
WARNING: Server certificate chain does not end with trusted root cert!
2012/05/10 11:56:29 main ani MESSAGE AniMain: Properties will be read from C:\PROGRA~2\CSCOpx\campus\etc\cwsi\ANIServer.properties
_Orb=org.jacorb.orb.ORB@343bb6
2012/05/10 11:56:29 main ani MESSAGE AniEventMgr: Event Manager has been enabled
PBPB: EventSource::realCtor(): bind to event factory :EDSFactory on host=PPCISCOWORKS
orbProperties={org.omg.CORBA.ORBInitialPort=42342, org.omg.CORBA.ORBClass=org.jacorb.orb.ORB, org.omg.CORBA.ORBInitialHost=PPCISCOWORKS, org.omg.CORBA.ORBSingletonClass=org.jacorb.orb.ORBSingleton, jacorb.implname=CSEDSPersistentIOR, org.omg.PortableInterceptor.ORBInitializerClass.bidir_init=org.jacorb.orb.giop.BiDirConnectionInitializer}
May 10, 2012 11:56:36 AM ES_PPCISCOWORKS__1336665389895 PPCISCOWORKS Debug ByteToObject: constructed
May 10, 2012 11:56:36 AM ES_PPCISCOWORKS__1336665389895 PPCISCOWORKS Debug EDSClassLoader: init_connection:
May 10, 2012 11:56:36 AM ES_PPCISCOWORKS__1336665389895 PPCISCOWORKS Debug EDSClassLoader: constructed
PBPB: EventSource::realCtor(): factory.createSourceConnector() = 0, ES_PPCISCOWORKS__1336665389895
Trying to get the already bounded object
In classlist loader
In classlist loader processing sub classes
updation done
In classlist loader completed
2012/05/10 11:56:36 main ani MESSAGE DBConnection: Created new Database connection [hashCode = 8796481]
2012/05/10 11:57:01 main ani ERROR POStore: Cannot resolve column deviceDbId of object dbId=277071, table=WbuModule, refDbId=206831
2012/05/10 11:57:01 main ani ERROR POStore: Cannot resolve column deviceDbId of object dbId=277073, table=WbuMib2Interface, refDbId=206831
Michel Hegeraat
Level 7
Level 7
Try to add a  .   after this line in the ANIServer .properties
DEVICESROOT=C:\\PROGRA~2\\CSCOpx\\campus\\lib\\classpath
Don't ask me how that . got lost or why it should be there in the first place
Cheers,
Michel
