LMS 4.1 - Monitoring Threshold Script
MaliqueVince
Good Morning,
I would like to create a higher level for theshold monitoring on LMS 4.1.
By default there are 3 Level (Criticial, Medium and Low), I would like to receive an additionnal alarm for my template.
In the threshold configuration there are a field "Execute Script".
Would it be possible to create a higher alarm with a script ?
If Yes : I can't find documentation about this.
I follow steps on this documentation but I don't know the syntax of the script
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.0/user/guide/monitoring_troubleshooting/mnt-setup.html
Someone could explain me the syntax for the script ?
Maybe an example of script ??
If No : Could there be a solution to add an higher alarm ? and How ?
Thank's for your consideration,
Cordially Vincent Malique
Vinod Arya
Doesnt seems possible to create another severity level of a threshold voilation. There are only three. You can modify the threshold criteria of an existing threshold using the Edit button. You can only make changes to the threshold criteria and the selection of instances. You cannot make changes to the threshold details (Threshold Name, Template Name, Variable Name).
Execute Script, is an option to run external command or script to be executed when threshold violation occurs.
-Thanks
Vinod
**Rating Encourages contributors, and its really free. **
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Vinod Arya
-Thanks
Vinod
Okay, thank's I will think about an other methodology.
Thank's for all.
