LMS 4.1 - Netconfig not working.
laerciotobias
After i discovered my network i have tried to use netconfig  and i was unnable to use it, i have selected the device and the the task  with no problem but at  the "add task" area it dosen't show anything at the "Applicable Task"area
Any ideas what this could be ?
Thanks.
Vinod Arya
This is very vague and it will be helpful to see some screeshot on what actually the issue is. Is it happening with all the devices?
-Thanks Vinod **Rating Encourages contributors, and its really free. **
dynamitec1
Check the applicable devices from your template.  Even when I had specifically included my 3750-E, it was giving me the same error.  So, my workaround was to actually include all Switches and Hubs.
Config > Tools > NetConfig > User Defined Task
Select "Device Type"
Then I was able to move on with the deployment.
