LMS 4.1 Patch Distribution Failure
xcz504d1114
Level 7
Level 7
I didn't have this problem in 4.0, and I've tried to upgrade 2 different model routers (891 and 2811) with the same error, anyone know what this means? Google was no help.
SWIM0151: The device is not running IOS Modular image in Install mode. Hence patch images cannot be distributed.
Craig
Joe Clarke
It sounds like you're trying to use the Pathc Distribution workflow for non-modular devices.  Do not select Patch Distribution.  Instead, select Software Distribution, and then follow the specific flow you want from there.
Joe Clarke
Joseph, as always, thank you very much!
Craig
