Bookmark
Subscribe
696
Cisco Devices Discovering By LMS 4.0
chs.gov.sa
Hi Experts
I have LMS 4.0 server installed without any problems on windows server Enterprise edition service pack 2 then i enabled SNMP on cisco switches and routers by the following commands
snmp-server enable traps
snmp-server enable traps snmp
snmp-server host 10.10.100.50 version 2c Beta
snmp-server BetaC RO
But when i tried to discover cisco devices and after trying many times theres no result so kindly to provide me in the correct commands which i have to enable on cisco devices . and if plz tp advice me .
Best Regards
A.ZABIN
d-yakobobich
The commands:
for snmp v2-
snmp-server community Beta ro
snmp-server host 10.10.100.50 Beta
Good luck.
thanks dana ,
The following is show run of one switch but till now cant discover this device by lms 4.0
interface GigabitEthernet0/26
switchport access vlan 20
switchport mode access
switchport voice vlan 21
spanning-tree portfast
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface GigabitEthernet0/29
interface GigabitEthernet0/30
interface GigabitEthernet0/31
interface GigabitEthernet0/32
interface GigabitEthernet0/33
interface GigabitEthernet0/34
interface GigabitEthernet0/35
interface GigabitEthernet0/36
interface GigabitEthernet0/37
interface GigabitEthernet0/38
interface GigabitEthernet0/39
interface GigabitEthernet0/40
interface GigabitEthernet0/41
interface GigabitEthernet0/42
interface GigabitEthernet0/43
interface GigabitEthernet0/44
interface GigabitEthernet0/45
interface GigabitEthernet0/46
switchport trunk native vlan 100
switchport mode trunk
interface GigabitEthernet0/47
interface GigabitEthernet0/48
interface GigabitEthernet0/49
interface GigabitEthernet0/50
interface GigabitEthernet0/51
interface GigabitEthernet0/52
interface Vlan1
no ip address
interface Vlan100
ip address 10.10.100.5 255.255.255.0
ip default-gateway 192.168.20.1
ip classless
ip http server
snmp-server community Beta RO
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
snmp-server enable traps transceiver all
snmp-server enable traps tty
snmp-server enable traps eigrp
snmp-server enable traps cluster
snmp-server enable traps entity
snmp-server enable traps cpu threshold
snmp-server enable traps power-ethernet group 1
snmp-server enable traps power-ethernet police
snmp-server enable traps rep
snmp-server enable traps vtp
snmp-server enable traps vlancreate
snmp-server enable traps vlandelete
snmp-server enable traps flash insertion removal
snmp-server enable traps port-security
snmp-server enable traps auth-framework sec-violation
snmp-server enable traps dot1x auth-fail-vlan guest-vlan no-auth-fail-vlan no-guest-vlan
snmp-server enable traps envmon fan shutdown supply temperature status
snmp-server enable traps cef resource-failure peer-state-change peer-fib-state-change inconsistency
snmp-server enable traps config-copy
snmp-server enable traps config-ctid
snmp-server enable traps hsrp
snmp-server enable traps energywise
snmp-server enable traps bridge newroot topologychange
snmp-server enable traps stpx inconsistency root-inconsistency loop-inconsistency
snmp-server enable traps syslog
snmp-server enable traps mac-notification change move threshold
snmp-server enable traps vlan-membership
snmp-server enable traps errdisable
control-plane
alias exec a shu run
alias exec c config t
alias exec s show ip interface b
alias exec r show ip route
line con 0
logging synchronous
line vty 0 4
login local
line vty 5 15
login
end
