lms 4.1 prime virtual soft appliance ova
a.olsthoorn
Beginner
Beginner
Hi all,
First of all I would like to thank everyone who contribute to this forum, it's a great help for me!!
My question:
I need to install a virtiual appliance LMS 4.1 with two network interfaces. On interface for the network management vlan and the second for the user vlan.
The network managers can only connect through the user-vlan.
Default the startup wizard supports one interface.
Q:
- can we select and configure one more?
- can we configure a second interface on the shell (regular linux commands)?
- is this supported?
kind regards
Ad Olsthoorn
Eduardo Aguilar
Beginner
Beginner
Hi Ad,
I finished checking the official documentation and there is no option to add a second interface for LMS, you can check this from the link below http://tools.cisco.com/squish/AdD9b Regarding your other questions, although it might be possible to configure a second interface (like using alias) this won't be supported for the LMS installation since it might cause some problems with the regular operations of the application (i.e. sync archive).
Recognize Your Peers
