02-21-2012 07:27 AM
Role management in LMS 4 is a nightmare.
Is there a documentation which map the tasks and the portlets ?
For exemple, which tasks do i need to view device availability portlet ?
Solved! Go to Solution.
02-21-2012 12:25 PM
Try to create a new role. you can safely do that.
Then you see the tree sturcture of possebilities.
Still it is not so easy to match the names to the actual portles or reports.
Cheers,
Michel
02-21-2012 12:25 PM
Cheers,
Michel
02-22-2012 04:35 AM
Thks for reply.
It was what i try. But it is time consuming...
Don't undestand such a doc doesn't exist.
02-22-2012 08:28 PM
It helped me to copy the existing system generated roles and use those as a template for my own role generation. For example, I wanted to have a role that could view all configuration and device information for a select group of devices, but could not write any changes to the devices. The HelpDesk role almost does this but even some of the performance reporting was unavailable to them. The HelpDesk and Network Operator roles combined had just a bit too much authority, but I started with those two roles as a template and then removed configuration capabilities from the new role and had my own role with View only capability. It's a bit time consuming, but much easier if you start with the roles they give you.
