LMS 4.2.2 how to automatically resolve the hostname for device identity?
Lonemaker
iam running lms 4.2.2 and i do not know where to set up lms to resolve the hostname for device identity.
In "Inventory/Manage Devices /Device identity", having the "Device Name", "Hostname" and "IP Address" set to the discovered IP (f.e. 10.100.100.20).
I want that the "DCR Device Name"  and "IP Address" is the discovered ip (10.100.100.20), but not the hostname (should look like AS100_Swtich_00-1, as it is set on the switch).
Editing the hostname manually for over 1000 discovered devices will be inefficient...
regards,
_____________
CCNP R&S
CCNP R&S
Michel Hegeraat
Level 7
Level 7
You can make LMS use the sysname as display name in the global settings
Or you can create a hosts file based on what you see in the discovery report.
I suggest the later because fault management does not use the dispay name of LMS but does his own DNS lookup when te devices is added
Cheers,
Michel
KAROLY KOHEGYI
Level 2
Level 2
I have a same problem.  i send the screenshot which shows where you can set what will be the preferred device name. ( earlier the sysname checkbox was ON )
Unfortunetly after discover and inventory upgrade jobs the device names are not restored to IP, they keep the hostname as preferred device name.
Now i do not know how can i change these settings automatically.
