LMS 4.2.3 - DCRServer stuck in state: Waiting to initialize
mbilgrav
Level 3
Level 3
Hey Forum,
One of my installation has gone stuck ... OVA install with SP3, has run great until now ...
I had problems with DCR, and restarted the daemons via Shell-CLI.
Did not start up again ...
Then reload via nomal-CLI
Then I noticed this when issuing "show application status LMS"
DCRServer             Waiting to initialize.
and it is stuck in this status
in daemons.log i see this and similar:
03/Sep/2013 16:11:45:964 ERROR  ? ?  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
In EPMOgsAdapter:since isOGSup is not true
03/Sep/2013 16:11:55:968 ERROR  ? ?  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
ms.ctm.common.CTMException: URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
03/Sep/2013 16:12:01:737 ERROR  ? ?  - URN_NOT_FOUND : urn "TIS-1.0" : Not found !!
com.cisco.nm.trx.tis.service.TISServiceException: URN_NOT_FOUND : urn "TIS-1.0" : Not found !!
at com.cisco.nm.trx.tis.service.TISRemoteServiceFactory.getService(TISRemoteServiceFactory.java:51)
at com.cisco.nm.trx.tis.service.TISServiceFactory.getService(TISServiceFactory.java:32)
at com.cisco.nm.trx.tis.service.TISService.getService(TISService.java:169)
at com.cisco.nm.trx.tis.service.TISService.<init>(TISService.java:192)
at com.cisco.nm.trx.tis.service.TISService.<init>(TISService.java:180)
at com.cisco.nm.trx.tis.service.TISService.getInstance(TISService.java:130)
at com.cisco.nm.trx.epm.providers.inventory.EpmTISInventory$InnerFactory.getInstance(Unknown Source)
at com.cisco.nm.trx.epm.providers.inventory.EpmTISInventory.tis(Unknown Source)
at com.cisco.nm.trx.epm.providers.inventory.EpmTISInventory.getMOId(Unknown Source)
at com.cisco.nm.cesar.kernel.binding.EventBinder.processNormalizedEvent(Unknown Source)
at com.cisco.nm.cesar.kernel.binding.EventBinder.run(Unknown Source)
at java.lang.Thread.run(Thread.java:662)
03/Sep/2013 16:12:02:770 ERROR  ? ?  - URN_NOT_FOUND : urn "TIS-1.0" : Not found !!
at com.cisco.nm.cesar.kernel.binding.EventBinder.processNormalizedEvent(Unknown Source)03/Sep/2013 16:12:02:770 ERROR  ? ?  - URN_NOT_FOUND : urn "TIS-1.0" : Not found !!
In EPMOgsAdapter:EPMOgsadapter is sleeping. Waiting for OGSServer to come up com.cisco.nm.xms.ctm.common.CTMException: URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
03/Sep/2013 16:12:05:973 ERROR  ? ?  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
03/Sep/2013 16:12:05:974 ERROR  ? ?  - URN_NOT_FOUND : urn "ogs_server_urn" : Not found !!
03/Sep/2013 16:12:06:649 ERROR  ? ?  - URN_NOT_FOUND : urn "TIS-1.0" : Not found !!
In the release note i find this:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.2.3/release/notes/lms4_2_3_release_notes.html
Table 2 Open Bugs in Cisco Prime LMS 4.2.3
CSCuc82281
  .. DCR Server takes long time to initialize.
  ... This happens when there are lot of files in < NMSROOT>/log directory.
So i have removed all files i  /var/adm/CSCOpx/log/ ( i only had 252 files, which is not "a lot")
started again:
/etc/init.d/dmgtd start
But still same issue ...
I am think of upgrading to SP4, but the bug is still open in SP4 aswell, so i am not sure this will fix it
Please help
regards
Martin
AFROJ AHMAD
Hi Martin,
Check the below things:
Make sure files
/opt/CSCOpx/MDC/tomcat/shared/lib/ctm_config.txt and
/opt/CSCOpx/MDC/tomcat/webapps/cwhp/WEB-INF/lib/ctm_config.txt has proper content.
/opt/CSCOpx/MDC/tomcat/lib/ctm_config.txt has proper content.
File  should not be empty. Check any working server (If any available or just  send me these files)  for the content, copy and replace
Also send me the pdshow output ,if above does not help..
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
7 Replies 7
AFROJ AHMAD
Hi Martin,
Make sure files
Afroz
Hallo Afroz,
Thanks for your reply.
In the meantime I was tempted to upgrade to SP4 - so i did and the server can up ...
Got som other problems with utm database and poller being disabled ... but i think its ok now ..
Anyways - the files are now almost identical now, so I think we need not to concern around this issue anylonger
Hi Afroz,
Thx for your nice post. I think I was running into the same problem after running the rmeptt.sh script at 4.2.5 Linux VA.
I think the last file from your explanation was destroyed by ptt
[lms4/root-ade bin]# ls -l /opt/CSCOpx/MDC/tomcat/lib/ctm_config.txt
-rwxr-xr-x 1 casuser casusers 52 Jul 28 16:00 /opt/CSCOpx/MDC/tomcat/lib/ctm_config.txt
[lms4/root-ade bin]# cat /opt/CSCOpx/MDC/tomcat/lib/ctm_config.txt
#CSTM Configurations
#Mon Jul 28 16:00:20 CEST 2014
So I want to ask if you can provide an /opt/CSCOpx/MDC/tomcat/lib/ctm_config.txt for 4.2.5?
thx, Steffen
Hi Steffen,
I have attached the file.
stop the daemon manager
replace the file , make sure the new file have all the required permission.
start the daemon manager
Let me know how it works..
Thanks-
Afroz
Hi afroz,
thx, problem has been resolved with this action
Steffen
Hello Afroj,
Can the attached file be used for LMS 4.2.3 as well?
The content of my /opt/CSCOpx/MDC/tomcat/lib/ctm_config.txt  is the following:
[ZVS1361U/root-ade lib]# vi ctm_config.txt
#Thu Sep 03 21:29:05 EDT 2015
I assume it's corrupted, right?
Hi Mehdi,
Yes ,it is corrupt..
and you can use that file.. should take care of the issue...
Thanks-
Afroz
