LMS 4.2.4 Topology Services starting slow
Tobias Heisele
when I starting Topology Services, it takes up to 10 minutes before the Java window appears. Checking the Java console, I found this entries (not only for cmtop-sign-1.3.jar):
Missing Permissions manifest attribute for: https://dest-ciscoprime01:443/JSP/CAMPUS/campus/res/cmtop-sign-1-3.jar
Missing Codebase manifest attribute for: https://dest-ciscoprime01:443/JSP/CAMPUS/campus/res/cmtop-sign-1-3.jar
Any idea how to fix this?
I am using it and i faced the same issues but after uninstalling all previous versions of Java, now it is working fine.
AFROJ AHMAD
Hi ,
1.
Clear the browser cookies and check the issue again.
2.
If possible , Uninstallaed all the existing java from the client and then Installed the JAVA from LMS ( as soon as you click on topology services > it will give you the option to installed the Java version which is compatible with you LMS version)
3.
Also check your user id should  have  FULL Premission on c:\prgraom files\java\jre\lib\endrosed   directory.
I hpope this will help
Thanks-
Afroz
[Do rate the post]
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
After uninstalling all "old" Java 1.6 versions, suddenly Topology Services are starting as "fast" as allways ;-)
