LMS 4.2.5 and Software Distribution
mbonet1976
I am tasked with upgrading the IOS of over 500 devices and would like to LMS to do this.  I have a test switch that I've tried this on several times and it keeps failing.  Because of the nature of the business, we are only allowed to use secure protocols so I am trying to do this using SCP.   We are not allowed to use TELNET or TFTP at all.  I have successfully been able to import images from switches so I don't understand why it isn't working in reverse.  Here is an example of one of my attempts:
JOB ID - 2211 SUMMARY
Device Name :  TEST_Switch
Software upgrade result - Failed
Total number of devices  scheduled for upgrade : 1
Number of devices  upgraded : 0
Number of devices failed : 1
Total time taken for Job - 3 Minutes 28 Seconds
Status of Job - FAILED
Starting Job: ID -  2211
Job Started At : Wed Oct 23 09:25:52 MDT  2013
Job running on : CiscoPrimeLMSServer
Upgrade Mode : Parallel
Reboot Mode : Parallel
Protocol Order for Image Transfer : SCP
Protocol Order for Config-operations :  SSH,HTTPS,SCP
Total  number of device(s) to be processed : 1
Processing Device : TEST_Switch
Start Time : Wed Oct 23 09:27:10 MDT 2013
Device is locked for  exclusive access.
The  supported protocols for image transfer are: SCP
Connecting to the device using TELNET...
Couldn't connect using TELNET...
Couldn't connect to the device
Cause: SWIM5001: Cannot connect to the device xxx.xxx.79.87 using TELNET.
Skipping the software  upgrade on this device.
Image Copy Operation  Failed
Device is  unlocked.
Device  Upgrade Result : Failed
End Time:Wed Oct 23  09:27:41 MDT 2013
Job Ended At : Wed Oct  23 09:29:20 MDT 2013
Is it necessary for TELNET to be used?  I thought SSH was an option as well.  I've also attached the log file.  I've replaced real identifying information (server name and IP address for security purposes) Please help!
mbonet1976
FYI, also seeing this on the test switch:  SSH2 2: alloc 37888 not supported.
