LMS 4.2 Portlets
bm_5789
I installed lms 4.2 and ran the first discovery.  Everything looks good.  What I am seeing is under My Menu -> My Dashboards -> Click on Functional, I am seeing a some strange screens I have never seen before.  I have attached a screenshot of what I am seeing.  If anyone knows what is happening, I would appreciate hearing from you.  TIA
Nael Mohammad
Level 5
Level 5
Do you get the same behavior using the public dashboards vs the private dashboards? Anything under "My Dashboards" are private so you might want to remove the portlets and re-add them to see if the problem persists. If it does, stop the LMS and restart and get the cwportal.log from CSCOpx/log directory.
