LMS 4.2 with couple of actions
Ibrahim Jamil
Level 6
Level 6
Hi All
how can i make lms 4.2 do the following ations:
1)how to add e-mail of users to lms in order to receive mails from lms
i already configured lms with smtp server of our enterprise
2)send email to users only with a critical status
2)only send alram with critical status to be shown on main window of lms 4.2
thanks
8 Replies 8
secureIT
Level 4
Level 4
Pls use DFM email notification, event sets etc to accomplish this task.
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/4.0/navigation/guide/dfmtask.html
Pls rate if this was helpful.
Hi Rajesh
do you pdfIncludes screen shoot mentioned that
will attach tomorrow.... But i suggest you to give a try, its very easy
Hi Rajeh
thanks for ur reply
you know my freind . ACS 5.x and Prime LMS 4.2 Less documented with guide includes steps and screen shoot
thanks
Hi Jamil,
I do not have much handson on ACS. But I shall check and update you the DFM/Email configuration
regards
Pls try this...
There is a legacy Button on top right corner, select DFM, then select Event sets and select the required triggering fields like flap, operationallydown etc... and make it as A (there is a tick mark available to group all these fields under 'A' group.
Secondly, go to email notification group and select all the devices which you want to monitor and select Alerts and over there select 'A', then select Critical, Warning etc, click next next...
For rest of it, pls go by the logic.
E-Mail Configuration Tasks
Managing E-Mail Notification Subscriptions
CiscoWorks LMS Portal > Device Fault Manager > Notification Services > E-Mail Configuration > E-Mail Notification
Admin > Network: Notification and Action Settings > Fault - Email notification
The E-Mail Notification Subscription page displays information about subscription, status and notification group.
Hi Rajesh
thanks for ur reply
pls can y help in the below thread
https://supportforums.cisco.com/message/3789594#3789594
thanks
Hi Jamil,
You need to finetune your ACS to get the required restrictions to users... In LMS you have limited restrictions like guest, network operator, system administrator etc.. More options are available in ACS.
regards
