Cisco ASA 8.4.5 NetFlow issue
prawin_2608
Hi Everyone,
I am monitoring the Cisco ASA 8.4.5 with two different monitoring software using NetFlow export. Until I upgrade to 8.4.5 everything was working fine, but after upgrade to this IOS version, the monitoring softwares are not able to parse the details. Please let me know is there any issue specific to NetFlow epxort observed on Cisco ASA 8.4.5.
jakewilson
Hello Praveen,
The NetFlow export changed in v8.4(5).  Details can be found in the blog:
Cisco ASA 8.4(5) NetFlow Support
The changes were for the better but, your NetFlow reporting solution will need updates. Hope that helps.
Please vote on my post if it helped you.
Jake
