LMS 4.x - SNMP Trap Forwarding - entries not removable
hgans
I see no possibility to remove existing entries under:
Admin > Network > Notification and Action Settings > Fault - SNMP trap forwarding
If you just delet existing entries and apply an error message occurs "Please enter destination host and port"...
So how to remove Trap Forwardings in GUI???
I know there is the manual option altering the NMSROOT/objects/smarts/conf/trapd/trapd.conf file, but since it is not supported....
Cheers
Herwig
This is still a problem seven years later. Anyone who can tell me how to remove such an entry in LMS 4.1?
