LMS - Alerting
colmgrier
Level 4
Level 4
Can LMS monitor 3rd party servers? Customer want LMS to send an e-mail alert when server IP address is unreachable.
Is this possible?
C
2 Accepted Solutions
Ferenc Kuris
Level 2
Level 2
You should monitore that interface to what the server is attached, and monitor it's status. You can do it here: Monitor -> Fault settings -> Setup -> Fault device details. Click onthe switch, view, click on it's name, and set the interface to true.
I would set up an IP SLA. But if you monitor the interface, you monitor the server, too  or is it a virtual server?
Br,
Frank
Ferenc Kuris
Level 2
Level 2
Thanks Ferenc.
Any way to monitor the IP address of the server?
regards,
C
Br,
Frank
