lms cookies disabled
yoguz
Hi there,
I have LMS running on a server but unfortunately, I can't login to my LMS. At the home page as you know there are three parameters to check:
JavaScript = Enabled
Java = Enabled
Cookies = Disabled
I have an other server just the same configuration it runs and all the three values are Enabled. And there is no problem with login into that one.
Is there any idea to fix this situation?
yasemin.
David Stanford
Are you logging into all 3 servers via the same client browser? What is the client browser settings for cookies?
I'm logging into 2 servers via the same client browsers ( i mean i tried this from too many clients and login to cookies enabled server, but can not to cookies disabled server).
yasemin.
