LMS data disk has filled up
marshajr
Level 3
Level 3
My LMS server data disk has hit 99% over the weekend - investigating this indicates a 381Gb file called DiscoveryStatusObj in CSCOpx is the culprit. What does this do, and how can I reduce it?
Joe Clarke
This file is a serialized Java class which holds all of the device data from the previous Discovery. Typically, this file doesn't become this large. If you need to, it can be safely deleted.
Joe Clarke
