LMS Discovery
trimmy
Hi, using LMS 3.0 I have discovered multiple devices from Campus Manager. However 2960s with different PIDs on LAN LITE IOS appear as unknown device type? Therefore I am unable to collect configs, Inventory etc. - I do have other 2960s on the system, lots of them so I know it is not a device pack issue. Has anyone come across this?
Thank you
Hi ,
The Device (WS-C2960S) is not supported in LMS 3.0.1 (CM 5.0.1) :
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.0.1/device_support/table/lms301sdt.html
Please upgrade the  LMS from LMS 3.0.1  to  LMS 3.2 and its free for you as it would be a Minor Upgarde :
You  can download the Evaluation version of LMS 3.2 from the below link and  you do not need a different License for LMS 3.2 you Existing License of  LMS 3.0.1 would work Perfectly.
https://cisco.mediuscorp.com/market/networkers/homeWork.se.work
Supported device list of LMS 3.2:
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_lan_management_solution/3.2/device_support/table/lms32sdt.html
Thanks--
Afroj
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
AFROJ AHMAD
HI ,
Try to Update the Device Packges of Campsu Manager and see how it works !!!
Go to common service > software center > Device Update >>> Select Campus Manager > click on check for updates  and update the Device pacakges ...
Thanks--
Afroj
Thanks Afroj - I have tried that already and I get a message saying there are no availabl
e updates. I am on CM 5.0.1,do you have any further
suggestions?
Hi ,
Thanks--
Afroj
this sounds good to me - I should have checked the compatability
matrix.
Thanks again for your time and assistance.
