lms flapping notification
ggittins
Level 2
Level 2
how can i disable the flapping notification of the alarms in LMS?
5 Replies 5
Joe Clarke
Is it that you do not want DFM to create flapping events at all, or you just don't want to receive notifications about it?
dont want to recieve notification about it.
Go to DFM > Notification Services > Event Sets, and create an event set which only includes the desired events for which you want notifications. Then, define a Notification Group, and only check the boxes for event severity and event type. Choose the configured event set from the pull-down.
If you don't choose the flapping event, then you should no longer receive notifications for those events.
thanks
