CiscoWorks2000
alsayed
Level 7
Level 7
Hello
I Tryed To Unstall CiscoWorks 2000 on Win2000 Server with SP4,But I Faced a POP UP while i m Intalling
TE RME That IIS version Required Althoug with Win200server the IIS installed is Version 5;
Plz Help me to Intall the Software...
N:B I Have attached the Image files
THANKS
Joe Clarke
The version of CiscoWorks you are installing is obsolete, and no longer supported. You will need to upgrade to CiscoWorks LAN Management Solution 2.6 or higher. The latest version is currently LMS 3.2. More on LMS can be found at http://www.cisco.com/go/lms .
