LMS groups
georgeef1
Level 4
Level 4
We are trying to creat more groups in CS and it gives an error as :
"You have exceeded the maximum number of User Defined Groups. The limit is 200"
Is that the max. limit or is there a way we can increase it?
Or is it a Bug?
-Please advise.
Joe Clarke
This is the max, and yes, you can increase it. However, more than 200 is not supported, so you may run into problems, and TAC would require you to decrease the ceiling to 200 before troubleshooting.
If you're okay with that, you can modify the OGSClient.properties file under NMSROOT/MDC/tomcat/webapps/cwhp/WEB-INF/classes, and increase MaxLimitforGroups.
