LMS Installation Data Collection Failure
I have decided to reload Cisco Works. Good morning. I recently installed CW 3.0 in a work group. Installed on a Server 2003 Standard Edition sp/2 on a Dell Power Edge 2850, CPU 3.0 and 1.99 GHz, 2 GB Ram, CWCS 3.1.1, CManager 5.0.3,CView 6.1.7, CWAssistant 1.0.1, DFmanager 3.0.2, IPMonitor 4.0.1, LMS Portal 1.0.1 and RME 4.1.1. I am unable to collect switch information. After restarting Server in an attempt to cancel an retrivial request I now get the following Device Discovery in IPaddress - Failed, the ip address is my server not the seed device.
Joe Clarke
I do not understand what you're seeing. Can you post a screenshot illustrating what you're doing and the error you see?
J.
I am sure that I have improperly set CW's up from the get go. So I've decided to reload and attempt another approach. I will keep you updated. Thanks
