LMS leaving SSH sessions open
craig bache
Hi All
I am hoping someone can help on the following issue.
Cisco Works (LMS 3,2)  is not closing SSH sessions to a Cisco ACE module, I see the following thread and tried the workaround to no avail.
https://supportforums.cisco.com/thread/2101729
I have also seen the following caveat (CSCtz42393) but this seems to be LMS 4.x, would this be 4.x and below or do I need to find the equivalent LMS 3.2
Regards Craig
7 Replies 7
Jorge Bejarano
Level 4
Level 4
Craig,
LMS 3.2 is End of Life Support.
http://www.cisco.com/en/US/prod/collateral/netmgtsw/ps6504/ps6528/ps2425/end_of_life_notice_c51-543581.html
I suggest you to upgrade to 4.2(3) where it says it has been fixed that and other similar bugs.
Jorge
AFROJ AHMAD
Hi Craig,
Temporarily , you can try restarting the ConfigManagement Server
pdterm ConfigMgmtServer
pdexec ConfigMgmtServer
I hope this will help
Afroz
Thanks- Afroz [Do rate the useful post] ****Ratings Encourages Contributors ****
Thanks for the response's, Afoz restarting the Configmanager server does this have any service impact?
Regards Craig
Hi Craig,
It will casue any issue
Afroz
Hi Afoz
Thank you for the response, was that it will not cause any issue.
Many thanks Craig
Hi My Bad    ,it was a TYPO mistake
Andy Johnson
Level 4
Level 4
Seeing this still in LMS 4.2.3 with ACE. SSH sessions are still being created and are stuck on ACE. Bug is not fixed.
