LMS patching - resolved, pls remove.
stevek1
Hi Folks,
How can I tell what patches (rme, cm, common services etc) have been installed on a LMS 2.6 server? Software Update shows me application versions, but I want to see what patches have been installed.
Cheers, Steve.
Resolved....
Can't see the forest for the trees - just realised I click on the product name and it drills down into patching details etc.
Joe Clarke
Under Software Update, click on the application name. The patches should be visible there under "Patches Installed".
Joe Clarke
thanks Joe, my brain cells were out to lunch for a few minutes - I had it sorted just after I posted it. Tried to delete the post but you have to request this from the moderator. Anyway, you were spot on as always. Cheers....Steve.
