03-04-2013 11:46 PM
Hi Everyone,
I am getting the following error mentioned below. Please advise.
thanks in advance.
regards,
AAMIR ABDUL WAHAB
03-05-2013 02:50 AM
Hi Aamir,
Try regenerating the SSL again, Follow the below link:
https://supportforums.cisco.com/message/3831028#3831028
Afroz
03-05-2013 05:12 AM
thank you very much for your reply Afroz. I have already followed the steps you mentioned above . but still getting the same error. also when i look at the errror log file it says " client denied by server configuration: LiaisonServlet " .
No idea whats going on ?
03-05-2013 05:18 AM
Kinldy send the stdout.log and stderr.log (NMSROOT/CSCOpx/MDC/tomcat/logs)
Any recent changes on the LMS server like change in HOSTNAME of the server or the IP address change ?
03-05-2013 09:01 PM
03-05-2013 09:41 PM
Dear Afroz,
i have not change anything on the server. last time i use logtot utility on syslog file because of big file size. all of a sudden LMS stopped showing data on the report. it generates report with empty data. then i restarted server and bingo!!!!! HELP
regards,
AAMIR ABDUL WAHAB
03-06-2013 04:50 AM
Hi Aamir,
Try to register and Unregistered the Apache:
to unregister:
pdreg -u Apache
to registered :
C:\PROGRA~2\CSCOpx\MDC\Apache\bin>pdreg -r Apache -e "C:\PROGRA~2\CSCOpx\MDC\Apache\bin\Apache.exe" -f "-d C:\PROGRA~2\CSCOpx\MDC\Apache -D SSL" -d TomcatMonitor
to confirm:
C:\PROGRA~2\CSCOpx\MDC\Apache\bin>pdreg -l Apache
Process = Apache
Path = C:\PROGRA~2\CSCOpx\MDC\Apache\bin\Apache.exe
Flags = -d C:\PROGRA~2\CSCOpx\MDC\Apache -D SSL
Startup = y
Dependencies = Tomcat
Note: you need to change the NMSROOT according to your server installed directory.
Now restart the Daemon Manager and check the issue again.
