LMS port number
shahkamrah
I want to change the port number used by LMS 2.6 from 1741 to 2000..Please let me know the procedure..
Correct. This will allow you to change both the HTTP port (default: 1741) and the HTTPS port (default: 443). You do not have to change both.
Joe Clarke
Solaris:
NMSROOT/MDC/Apache/bin/changeport
Windows:
NMSROOT\MDC\Apache\changeport.exe
With the help of this command
I hope that i will be able to open the LMS using the following url
http://:2000
Correct me if i am wrong
I worked thanks a lot
