LMS Prime 4.2 instalation fail
natomiast
I have problem with Cisco LMS 4.2 Prime installation.
My system specification:
Freash instalation of Windows Server 2008 R2 Enterprise Edition 64Bit on VMware vSphere Hypervisor 4.1 (ESXi server 4.1).
Hardware:
16GB RAM, 256 GB HDD, CPU E5420.
When I started installation I get an error:
ERROR: db not found
ERROR: Component db is not found.
mdcbase : depends on: cmfwd plug db ess
cdone : contains: cmfwd plug cmf mdcbase
Maybe someone know the solution for that error and can help
Thanks for any help
Joel Monge
It seems you are installing the service pack 4.2.2 without having installed base version 4.2.  Which exactly is the file you are running?
Dear Joel I am having the same above problem.
I have Cisco LMS 4.2.5 and i am installing it on windows server 2012 standard.
Please see the error in attachment.
Wainting for your reply.
You should ideally open a new thread, instead of replying to a 2 years old thread to continue. You could use link for reference.
Which Server version are you using? Is LMS 4.2 already installed on the machine?
LMS 4.2.5 is is not the entire installable package. It needs to have LMS 4.2 installed already. Following is the Upgrade path to LMS 4.2.5:
Current LMS Version
Type of Upgrade
Procedure
LMS 4.2.3
Remote migration
1. Install LMS 4.2.4 and take a backup of the LMS 4.2.4 data.
2. Install LMS 4.2.5
3. Migrate your backup data to LMS 4.2.5 using the instructions explained in the section Remote Upgrade to LMS 4.2.5.
Direct migration
The backup data is automatically migrated during installation.
LMS 4.2.2
Remote migration
Direct migration
LMS 4.2.1
Remote migration
1. Install LMS 4.2.2
2. Install LMS 4.2.4 and take a backup of the LMS 4.2.4 data.
3. Install LMS 4.2.5
4. Migrate your backup data to LMS 4.2.5 using the instructions explained in the section Remote Upgrade to LMS 4.2.5.
Direct migration
LMS 4.1
Remote migration
1. Install LMS 4.2 and take a backup of the LMS 4.2 data.
Direct migration
1. Install LMS 4.2
For details on installing procedure of LMS 4.2.5, please check its release notes here :
http://www.cisco.com/c/en/us/td/docs/net_mgmt/ciscoworks_lan_management_solution/4-2-5/release/notes/lms4_2_5_release_notes.html#14050
-Thanks
Vinod
**Encourage Contributors. RATE Them.**
-Thanks Vinod **Rating Encourages contributors, and its really free. **
