LMS PRIME 4.2 integrating with ACS 4.2
marwan malawani
i would like to integrate new lms prime 4.2 with acs.4.2 . .. !!
is there document or user guide for this version of lms?
Thanks in advance.
Marwan
Vinod Arya
IN LMS 4.2 there is nothing which is known as Integration (like LMS 3.x), since it added feature RBAC.
Now ACS can just be used as PAM to have ciscoworks authenticated for Tacacs+ or Radius. After the auth is done, you should have a authorization set in LMS locally for user, else it will be given a default HELP DESK access.
For more details check :
Authentication Using Login Modules - Overview
-Thanks
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Thank you a lot for these useful info ...
Marwan.
