06-28-2011 08:43 PM
Dear All
we installed a LMS 3.2 for our customer with HUM module.
when the customer using Hum to generate report, he found that the pre-defined report which
show the last 24 hours data, has graph with it.
but when he tried to generate another report for a shorter time frame, e.g. for the last 8 hours.
then this time the report wont have graph with it.
our question is how to generate a custom report with graph?
is it possible to do so with LMS 3.2?
thanks
Yuke
07-02-2011 02:17 PM
yes, you can create custom reports with the Graph. Its actually created with graph by default. The only thing you need to do after launching the custom report is that you need to click on the device which is hyperlink to Graph for the OID for which custom report was created.
Hope this is what you was looking for.
Gaganjeet
08-11-2011 06:05 PM
Hi Gaganjeet
thanks for u reply. I forwarded it to our customer, but still not able to get what u talking abt.
we are planning to open a TAC for this one.
thanks
Yuke
