06-02-2015 10:25 PM
I am looking for a device package that related to "1.3.6.1.4.1.9.1.1703",
and I can't find the link to download it.
Is there anyone can provide a link?
Thanks for help
06-02-2015 11:25 PM
Hi ,
you are sure about the sysobject ID that you have shared.
Object catWsC2960x48tsLL
OID 1.3.6.1.4.1.9.1.1703
I checked the supported device link, I don't see this device under supported table
http://www.cisco.com/c/en/us/td/docs/net_mgmt/ciscoworks_lan_management_solution/4-2/device_support/table/lms42sdt.html
Thanks-
Afroz
***Ratings Encourages Contributors ****
06-03-2015 06:16 AM
The CiscoView package is here. (scroll down in left column to see the Cat2960 packages)
The readme file indicates that version 20 introduced:
* WS-C2960X-48TS-LL(Blind Support) Catalyst 2960X 48 Gig Downlinks and 2 SFP uplink Non Stackable
I could not find any Topology or Fault Management packages specific to this device.
