10-12-2011 04:04 AM
We need also quick access from TopologyView for Telnet (beside SSH), but the documented procedure with the RegKey does not work.
Using IE8 and tried with Mozilla as well with same result.
Are ther any hints, thx Steffen
Solved! Go to Solution.
10-13-2011 01:26 AM
It sounds like you may have IE set to be your telnet protocol handler. IT also looks like you may have some weird spaces in your registry stuff. See this forum post to confirm your setup is good:
10-12-2011 04:17 PM
What RegKey procedure? It sounds like your client may not have telnet.exe installed. The Topo Map code will invoke telnet.exe as:
cmd /k telnet IP
Make sure that command is working.
10-13-2011 12:44 AM
MS telnet.exe is installed,
cmd /k telnet IP
works fine
In the LMS Online Help is written that you have to create an RegKey for Telnet.
10-13-2011 12:56 AM
What version of LMS is this? In 4.x you do need to make sure the telnet protocol handler is enabled in IE. However, this would not affect Firefox. Make sure your C:\windows\system32\cmd.exe allows read & execute access for everyone. What error do you get trying to launch telnet in each browser?
10-13-2011 01:21 AM
I added read & execute access for C:\windows\system32\cmd.exe to everyone (in DE "Jeder") at the Computer where I start the LMS-browser.
Than I launched toplogy in Mozilla, after accessing Telnet in context menu a IE-Explorer Windows opens trying to access telnet://
that shows "Die Webseite kann nicht angezeigt werden", means website is in accessable
The mentioned Regkey in LMS online help was:
[HKEY_LOCAL_ MACHINE\SOFTWARE \Microsoft\ Internet
Explorer\Main\ FeatureControl\ FEATURE_DISABLE_ TELNET_PROTOCOL]
"iexplore.exe" =dword:00000000
I gues it was the produre for the IE Telnet protocol handler???
10-13-2011 01:26 AM
10-13-2011 01:54 AM
thx a lot, it was a Copy&Pste Error from online help with leaving a trailng SPACE
"FEATURE_DISABLE_TELNE T_PROTOCOL "
