LMS why I have no access to device in RME ?
marekbudzisz
LMS 3.2 RME 4.3
I can't choose the device in RME, this device has the same configuration like others, place in the same group in ACS,
I have tried remove and add again ,nevertheless  nothing happened.
Please see the attached file.
Marek
Joe Clarke
What are the sysObjectIDs of these devices?
In LMS : Cisco Catalyst 2960-48PST-L Switch
and from device:
cisco WS-C2960-48PST-L (PowerPC405) processor (revision D0) with 61440K/4088K bytes of memory.
Cisco IOS Software, C2960 Software (C2960-LANBASEK9-M), Version 12.2(46)SE, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Thu 21-Aug-08 15:59 by nachen
Image text-base: 0x00003000, data-base: 0x01200000
ROM: Bootstrap program is C2960 boot loader
BOOTLDR: C2960 Boot Loader (C2960-HBOOT-M) Version 12.2(46r)SE2, RELEASE SOFTWARE (fc1)
System image file is "flash:/c2960-lanbasek9-mz.122-46.SE/c2960-lanbasek9-mz.122-46.SE.bin"
Last reset from power-on
2 Virtual Ethernet interfaces
48 FastEthernet interfaces
4 Gigabit Ethernet interfaces
The password-recovery mechanism is enabled.
64K bytes of flash-simulated non-volatile configuration memory.
Motherboard assembly number     : 73-11882-08
Power supply part number        : 341-0266-03
Motherboard serial number       :
Power supply serial number      : DCA1424H4NF
Model revision number           : D0
Motherboard revision number     : A0
Model number                    : WS-C2960-48PST-L
System serial number            :
Top Assembly Part Number        : 800-30874-04
Top Assembly Revision Number    : B0
Version ID                      : V03
CLEI Code Number                : COMC400ARA
Hardware Board Revision Number  : 0x01
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C2960-48PST-L   12.2(46)SE            C2960-LANBASEK9-M
SysObject ID
1.3.6.1.4.1.9.1.1016
Check your version of the RME Cat2960 package.  The latest is 6.4 and support for this 2960 switch is available.  If you do not have, go to Common Services > Software Center > Device Update and download and install all available updates for Common Services and RME.  Once that is done, RME will be able to fully manage these switches.
