LMS2.5.1 install problems
cowana
Community Member
Anyone seen this error before when starting the processes:
Aug 15 23:55:29 GOWATSRV02 dmgt[2793]: [ID 851568 local0.info] #3007:TYPE=INFO:Started application(Tomcat) "/opt/CSCOpx/MDC/tomcat/bin/catalina.sh run" pid=2913.
Aug 15 23:55:33 GOWATSRV02 dmgt[2793]: [ID 111377 local0.info] #3007:TYPE=INFO:Started application(Tomcat) "/opt/CSCOpx/MDC/tomcat/bin/catalina.sh run" pid=2929.
Aug 15 23:55:37 GOWATSRV02 dmgt[2793]: [ID 175883 local0.info] #3007:TYPE=INFO:Started application(Tomcat) "/opt/CSCOpx/MDC/tomcat/bin/catalina.sh run" pid=2945.
Aug 15 23:55:41 GOWATSRV02 dmgt[2793]: [ID 882407 local0.info] #3007:TYPE=INFO:Started application(Tomcat) "/opt/CSCOpx/MDC/tomcat/bin/catalina.sh run" pid=2961.
Aug 15 23:55:45 GOWATSRV02 dmgt[2793]: [ID 142216 local0.info] #3007:TYPE=INFO:Started application(Tomcat) "/opt/CSCOpx/MDC/tomcat/bin/catalina.sh run" pid=2977.
Aug 15 23:55:49 GOWATSRV02 dmgt[2793]: [ID 206722 local0.info] #3007:TYPE=INFO:Started application(Tomcat) "/opt/CSCOpx/MDC/tomcat/bin/catalina.sh run" pid=2993.
Aug 15 23:55:53 GOWATSRV02 dmgt[2793]: [ID 447008 local0.info] #3007:TYPE=INFO:Started application(Tomcat) "/opt/CSCOpx/MDC/tomcat/bin/catalina.sh run" pid=3009.
Tomcat won't start after installing. Help!
David Stanford
Can you check the following:
ls -l /opt/CSCOpx/MDC/etc/regdaemon.xml
If this is 0 in size then you may need to contact TAC to get a clean copy of the regdaemon.xml
No, I already saw the posts on this bug, but does not seem to be the problem I have. for some reason cygwin does not install when I install Common Services, therefore the command:
/opt/CSCOpx/MDC/tomcat/bin/catalina.sh run does not run (called by the daemon manager) and I get the following:
[GOWATSRV02]# /opt/CSCOpx/MDC/tomcat/bin/catalina.sh
/opt/CSCOpx/MDC/tomcat/bin/catalina.sh: cygpath: not found
/opt/CSCOpx/MDC/tomcat/bin/catalina.sh: system: not found
/opt/CSCOpx/MDC/tomcat/bin/catalina.sh: QIBM_MULTI_THREADED=Y: is not an identifier
I modified the catalina.sh script and removed the commented the lines out:
# For Cygwin, ensure paths are in UNIX format before anything is touched
# if $cygwin; then
# [ -n "$JAVA_HOME" ] && JAVA_HOME=`cygpath --unix "$JAVA_HOME"`
# [ -n "$CATALINA_HOME" ] && CATALINA_HOME=`cygpath --unix "$CATALINA_HOME"`
# [ -n "$CATALINA_BASE" ] && CATALINA_BASE=`cygpath --unix "$CATALINA_BASE"`
# [ -n "$CLASSPATH" ] && CLASSPATH=`cygpath --path --unix "$CLASSPATH"`
# [ -n "$JSSE_HOME" ] && JSSE_HOME=`cygpath --path --unix "$JSSE_HOME"`
# fi
# For OS400
# if $os400; then
# Set job priority to standard for interactive (interactive - 6) by using
# the interactive priority - 6, the helper threads that respond to requests
# will be running at the same priority as interactive jobs.
# COMMAND='chgjob job('$JOBNAME') runpty(6)'
# system $COMMAND
# For Cygwin, switch paths to Windows format before running java
# if $cygwin; then
# JAVA_HOME=`cygpath --path --windows "$JAVA_HOME"`
# CATALINA_HOME=`cygpath --path --windows "$CATALINA_HOME"`
# CATALINA_BASE=`cygpath --path --windows "$CATALINA_BASE"`
# CATALINA_TMPDIR=`cygpath --path --windows "$CATALINA_TMPDIR"`
# CLASSPATH=`cygpath --path --windows "$CLASSPATH"`
# JSSE_HOME=`cygpath --path --windows "$JSSE_HOME"`
# fi
As they are not need for the Unix environment since the paths are already formatted correctly.
This seems to work at the moment although only just got it working. I am planning to open a tac case to see if Cisco have any ideas why cygwin does not install.
