LMS3.2/Campus5.2.1/UT: device selector empty when generate reports
ebezombes
Customer has LMS 3.2 on windows. He has an issue on UT when he wants to generete a report, device selector is empty.
User Tracking -> Reports -> Report Generator:
      * Application : Switch Port Report
      * Report : Reclaim Unused Down
He has the same issue (device selector empty) with :
- Campus Manager >> Configuration >> VLAN Configuration
- Campus Manager >> Reports >> Report Generator >> Switch Port Report + Switch Port Summary
- Campus Manager >> Visualization >> RMON Configuration
I didn't find bug in BugID Lookup Tool.
Which logs could give me information for this issue ?
Many thanks
Thomas Masters
This sounds like a problem with Object Grouping Services where Campus OGS is not able to communicate with CMF OGS.
The shortest solution might be to just restart LMS, wait 15 minutes and then check again.
If that does not help,
1) Enable OGS debugging for both Campus and CMF
NMSROOT = C:\progra~1\CSCOpx or /opt/CSCOpx (unix)
NMSROOT/MDC/tomcat/webapps/cwhp/WEB-INF/classes/log4j-ogs.properties NMSROOT/MDC/tomcat/webapps/campus/WEB-INF/classes/log4j-ogs.properties
Change ALL instances of FATAL, ERROR, WARN, and INFO to DEBUG.
(might want to back these files up first, you will want to change them back when finished)
2) Restart LMS (wait 5 mins betweens stop/start)
windows
> net stop crmdmgtd
> net start crmdmgtd
unix
# /etc/init.d/dmgtd stop
# /etc/init.d/dmgtd start
3) Reproduce the problem
4) Collect Log files in
C:\progra~1\CSCOpx\log or /var/adm/CSCOpx/log (unix)
CampusOGSClient.log
CampusOGSServer.log
CMFOGSClient.log
CMFOGSServer.log
5) Open a case with TAC
Good luck
Tom
