LMS3.2 - Need Customized method for cofig archive to particular device.
Ram prakash
Hi all,
    We are using Cisco works LMS 3.2 - Added around 400 devices and monitoring the same.  Facing a issue like while taking a configuration backup getting all devcie details and also CONFIG_ARCHIEVE Job is time consuming, because getting all device configurations. To avoid this we need to know the customized method to archive target particular device configuration in the LMS 3.2 .
Can any one help on this...Thanks in advance.
Thanks and Regards
Ramprakash
Vinod Arya
This is possible. You can schedule a Archive job for perticular devices to run periodically, like every 6 hours, daily, weekly or monthly.
This can be done from :
RME > Config Mgmt > Archive Mgmt > Sync Archive
-Thanks
Vinod
-Thanks Vinod **Rating Encourages contributors, and its really free. **
Hi Vinod Arya,
Thanks for your response and support !
Thanks and Regards
Ramprakash
Hi Ram,
Good to know it helped.
Please mark your post as answered if it has been. You can always open new threads for any issues.
-Thanks
Vinod
