LMS4.1 SNMPV3
CSCO11616177
                   Dear,all
                              Who can give me a SNMPv3 configuration template.
                               I tried many times has been a problem
                    Thanks all
5 Replies 5
Marvin Rhoads
Have you tried using the system template for SNMP Security Configuration task as described in the Configuration Management guide?
Reference this link.
Hi,dear
               The link you give me,can't open
It's a customer-accessible link and should require any special entitlement beyond a registered user login. You should be able to get to it by first logging into cisco.com.
Alternatively you can navigate via the LMS support page to the document "Configuration Management with Cisco Prime LAN Management Solution 4.1".
Dear Marvin
            Can you give some help about Threshold Configuration?
           Why my E-mail just receive the Threshold Violation Information one times ?
It depends on what threshold you are referring to and how it's setup. The LMS 4.1 Monitoring and Troubleshooting Guide Chapter 2 explains in great detail.
