These problem about features in Cisco PI 1.2
Chien Ta Cong
Dear Cisco Support Team ,
Currently , I am using PI 1.2 .I have some confuses  about these features on this .
1. Alarm and Event :
- When 1 port on any devices down , I don't see any alarm about this . Plz tell me What kinds of alarm in PI ?
- I can't receive any syslog on these devices although I have configured  and received on LMS .
2. Client and Users :
- What is the client ? On some Switchs just has 24 ports but show more 24 clients .
Thanks!
predrag2006
Make sure that you have the syslog port unfiltered first. Also your IOS devices have to be configured to send SYSLOG messages to your Prime. This should work without any specific configuration. Send me output of "show application status NCS" after you SSH to the prime. Output should be something like:
NCS/admin# show application status NCS
Health Monitor Server is running.
Reporting Server is running
Ftp Server is running
Database server is running
Tftp Server is running
Matlab Server is running
NMS Server is running.
SAM Daemon is running ...
DA Daemon is running ...
Syslog Daemon is running ...
status
Regarding the client section please describe exactly what are you trying to ask ?
Predrag Petrovic
Predrag Petrovic
Hi Predrag ,
Thanks for advisors .
- About the syslog  :
I have configured syslog on device to send to PI , some devices can send to PI , almost switchs .We monitor 40 devices , have 9 switchs in the network but on PI just see syslog on 2 switchs , no syslog on all router  ? The flowing is status on PI :
     Last login: Mon Apr  8 14:08:41 2013 from 10.7.15.224
     srv-pi-01/admin# ncs status
     status
- About the Client :
For example :
I have 2 switchs  . They have connected ( Switch A-- Switch B on port 24 ). On 1 switch A have connect 1 router A  , from router A connected router B .
When I show client on PI on Switch B I see router B as client although it not connect with Switch B .
Plz help to check this problem .
