LMS4.2 processes unstarted after installing VMware Tools
Abel JULIAN
Yesterday I had a installation of LMS4.2.2 who was working fine. I followed the procedure to install VMware Tools on the virtual appliance on this thread :
https://supportforums.cisco.com/thread/2185999
Now I have a problem with the processes of LMS, but maybe it is not linked. I forget to do a snapshot before installing VMware Tools so I need to find a solution.
Here is the problem : A whole bunch of services do not start know. I tried to uninstall the VMware tools, to regenerate SSL certificate, I rebooted the server several times. It is running under VMware 5.1.
[SRVV-LMS/root-ade ssl]# /etc/init.d/dmgtd status
  Process               State                                     Pid
  ESS                   Program started - No mgt msgs received    31362
  EssMonitor            Running normally                          31402
  EventFramework        Program started - No mgt msgs received    31419
  SyslogCollector       Running normally                          31420
  RMEDbEngine           Program started - No mgt msgs received    31421
  DfmBroker             Running normally                          31536
  DfmServer             Running normally                          31618
  DfmServer1            Running normally                          31619
  FHDbEngine            Program started - No mgt msgs received    31620
  EPMDbEngine           Program started - No mgt msgs received    31876
  EPMServer             Program started - No mgt msgs received    31971
  AdapterServer         Program started - No mgt msgs received    32053
  AdapterServer1        Program started - No mgt msgs received    32054
  FHServer              Running normally                          32055
  INVDbEngine           Program started - No mgt msgs received    32056
  PMServer              Running normally                          32172
  IpmDbEngine           Program started - No mgt msgs received    32385
  UPMDbEngine           Program started - No mgt msgs received    32549
  UPMDbMonitor          Running normally                          32698
  ANIDbEngine           Program started - No mgt msgs received    32701
  MACUHIC               Running normally                          32738
  UTLITE                Running normally                          32739
  CmfDbEngine           Program started - No mgt msgs received    32740
  CmfDbMonitor          Running normally                          384
  DFMLogServer          Program started - No mgt msgs received    386
  DFMCTMStartup         Administrator has shut down this server   0
  FHPurgeTask           Never started                             0
  DFMMultiProcLogger    Program started - No mgt msgs received    388
  CSDiscovery           Never started                             0
  DCRDevicePoll         Never started                             0
  CSRegistryServer      Running normally                          389
  Tomcat                Program started - No mgt msgs received    398
  TomcatMonitor         Running normally                          486
  Apache                Running normally                          736
  DCRServer             Waiting to initialize.                    752
  CMFOGSServer          Never started                             0
  TISServer             Never started                             0
  DFMOGSServer          Never started                             0
  NOSServer             Never started                             0
  PTMServer             Never started                             0
  InventoryCollector    Never started                             0
  Interactor            Never started                             0
  InventoryCollector1   Never started                             0
  Interactor1           Never started                             0
  UPMProcess            Never started                             0
  WlseUHIC              Never started                             0
  UTManager             Never started                             0
  VNMServer             Never started                             0
  EssentialsDM          Never started                             0
  ICServer              Never started                             0
  EnergyWise            Never started                             0
  ConfigMgmtServer      Never started                             0
  PMCOGSServer          Never started                             0
  ConfigUtilityService  Never started                             0
  CAAMServer            Never started                             0
  IPMOGSServer          Never started                             0
  TopoServer            Program started - No mgt msgs received    1191
  LicenseServer         Program started - No mgt msgs received    1192
  FDRewinder            Never started                             0
  NameServer            Program started - No mgt msgs received    1193
  NameServiceMonitor    Program started - No mgt msgs received    1265
  EDS                   Running normally                          1285
  ANIServer             Never started                             0
  UTMajorAcquisition    Never started                             0
  EDS-GCF               Running normally                          1417
  jrm                   Running normally                          1418
  DataPurge             Administrator has shut down this server   0
  IPMProcess            Never started                             0
  CTMJrmServer          Never started                             0
  SyslogAnalyzer        Never started                             0
  ChangeAudit           Never started                             0
  diskWatcher           Running normally                          1525
Have you seen this before ?
Thanks by advance,
Abel.
5 Replies 5
Abel JULIAN
I opened a TAC Case and I have my answer. Cisco does not support VMware 5.1 for LMS...
I close the thread.
There is a big difference between not supported and not working.
Did the TAC just say, your problem. Reinstall?
VMware tools does not bother the running apps as far as I know.
In fact bringing down the daemon manager correctly before the OS shuts down is better for LMS health.
Cheers,
Michel
Hello Michel,
Yes it is a difference a I agree. But It already encoutered some issue with the 5.1 with other applications and I do not want to loose more time. I will reinstall a 5.0, it will be quicker than debugging. And I know Cisco, if it not supported they will no loose time to debug the product.
I always bring down the deamon manager before stoping the VM, I used to have some issue in the past with Windows versions corrupting LMS databases by rebooting.
Thanks anyway,
Abel
OK, I use an older version of the VMTools.
An it is configured only to make sure the OS shuts down nicely, no kernel modifications and that sort of thing.
I did not encounter any issues.
I do wonder how ESX 5.1 could possibly provoke the issue you saw.
Cheers,
Michel
I do not know either but VMware 5.1 has changed some parameters obviously that annoy application (some script Windows and so on).
I will wait until Cisco support this version to work on it for Prime.
Abel.
