Log Not Generate
vengatthiya
Cisco Switch 4503e Not Generate the logs
IOS - cat4500e-universalk9.SPA.03.04.05.SG.151-2.SG5.bin
Power Supply Up Down But Switch Was Not Generated The Logs
Mark Elsen
             - Do you have a syslog server configured correctly in the running configuration ?
 M.
Would you post the first several pages of output from the command show log? Also would be helpful if you post the output of the command show run | include log.
Rick
