11-19-2014 05:48 AM
For some reason I'm not finding the correct fourm to post this question. but maybe someone would be willing to help.
We mostly have a pretty complex network with a many routers and ASA's And I notice in our logging I'm seeing things that might be considered normal but to me I question it.
We hired a outside company to setup the network and I see alot of these messages in our logging. and I just wanted to see if these kinds of messages are normal or should we maybe get another group to take a look and see if we have any problems. Reason I'm mostly asking is over all something if our network seam slow and some of the routing I read in the configs seam a little off.
I had to change the IP address of public IP's to bogus numbers.
002-ASA 11-19-2014 05:30:41 %ASA-4-713903: IP = 001.001.001.001, Information Exchange processing failed
001-ASA 11-19-2014 05:30:40 %ASA-4-713903: IP = 002.002.002.002, Header invalid, missing SA payload! (next payload = 4)
002-ASA 11-19-2014 05:30:40 %ASA-5-713904: IP = 001.001.001.001, Received an un-encrypted INVALID_COOKIE notify message, dropping
001-ASA 11-19-2014 05:30:38 %ASA-4-752012: IKEv1 was unsuccessful at setting up a tunnel. Map Tag = outside_map. Map Sequence Number = 20.
001-ASA 11-19-2014 05:30:38 %ASA-3-752015: Tunnel Manager has failed to establish an L2L SA. All configured IKE versions failed to establish the tunnel. Map Tag= outside_map. Map Sequence Number = 20.
001-ASA 11-19-2014 05:30:32 %ASA-4-713903: Group = 002.002.002.002, IP = 002.002.002.002, Can't find a valid tunnel group, aborting...!
002-ASA 11-19-2014 05:30:32 %ASA-5-752004: Tunnel Manager dispatching a KEY_ACQUIRE message to IKEv1. Map Tag = outside_map. Map Sequence Number = 20.
002-ASA 11-19-2014 05:30:32 %ASA-4-752010: IKEv2 Doesn't have a proposal specified
002-ASA 11-19-2014 05:30:32 %ASA-5-713041: IP = 001.001.001.001, IKE Initiator: New Phase 1, Intf inside, IKE Peer 001.001.001.001 local Proxy Address 192.168.13.32, remote Proxy Address 192.168.52.0, Crypto map (outside_map)
002-ASA 11-19-2014 05:30:22 %ASA-3-752015: Tunnel Manager has failed to establish an L2L SA. All configured IKE versions failed to establish the tunnel. Map Tag= outside_map. Map Sequence Number = 20.
002-ASA 11-19-2014 05:30:22 %ASA-4-752012: IKEv1 was unsuccessful at setting up a tunnel. Map Tag = outside_map. Map Sequence Number = 20.
002-ASA 11-19-2014 05:30:14 %ASA-4-713903: IP = 001.001.001.001, Information Exchange processing failed
002-ASA 11-19-2014 05:30:14 %ASA-5-713904: IP = 001.001.001.001, Received an un-encrypted INVALID_COOKIE notify message, dropping
001-ASA 11-19-2014 05:30:14 %ASA-4-713903: IP = 002.002.002.002, Header invalid, missing SA payload! (next payload = 4)
002-ASA 11-19-2014 05:30:06 %ASA-4-713903: IP = 001.001.001.001, Information Exchange processing failed
002-ASA 11-19-2014 05:30:06 %ASA-5-713904: IP = 001.001.001.001, Received an un-encrypted INVALID_COOKIE notify message, dropping
001-ASA 11-19-2014 05:30:06 %ASA-4-713903: IP = 002.002.002.002, Header invalid, missing SA payload! (next payload = 4)
001-ASA 11-19-2014 05:30:04 %ASA-5-713041: IP = 003.003.003.003, IKE Initiator: New Phase 1, Intf inside, IKE Peer 003.003.003.003 local Proxy Address 192.168.52.0, remote Proxy Address 192.168.13.32, Crypto map (outside_map)
001-ASA 11-19-2014 05:30:04 %ASA-4-752010: IKEv2 Doesn't have a proposal specified
001-ASA 11-19-2014 05:30:03 %ASA-5-752004: Tunnel Manager dispatching a KEY_ACQUIRE message to IKEv1. Map Tag = outside_map. Map Sequence Number = 20.
002-ASA 11-19-2014 05:29:58 %ASA-4-713903: IP = 001.001.001.001, Information Exchange processing failed
002-ASA 11-19-2014 05:29:58 %ASA-5-713904: IP = 001.001.001.001, Received an un-encrypted INVALID_COOKIE notify message, dropping
001-ASA 11-19-2014 05:29:58 %ASA-4-713903: IP = 002.002.002.002, Header invalid, missing SA payload! (next payload = 4)
001-ASA 11-19-2014 05:29:56 %ASA-3-752015: Tunnel Manager has failed to establish an L2L SA. All configured IKE versions failed to establish the tunnel. Map Tag= outside_map. Map Sequence Number = 20.
001-ASA 11-19-2014 05:29:56 %ASA-4-752012: IKEv1 was unsuccessful at setting up a tunnel. Map Tag = outside_map. Map Sequence Number = 20.
001-ASA 11-19-2014 05:29:50 %ASA-4-713903: Group = 002.002.002.002, IP = 002.002.002.002, Can't find a valid tunnel group, aborting...!
002-ASA 11-19-2014 05:29:50 %ASA-4-752010: IKEv2 Doesn't have a proposal specified
002-ASA 11-19-2014 05:29:50 %ASA-5-713041: IP = 001.001.001.001, IKE Initiator: New Phase 1, Intf inside, IKE Peer 001.001.001.001 local Proxy Address 192.168.13.32, remote Proxy Address 192.168.52.0, Crypto map (outside_map)
002-ASA 11-19-2014 05:29:50 %ASA-5-752004: Tunnel Manager dispatching a KEY_ACQUIRE message to IKEv1. Map Tag = outside_map. Map Sequence Number = 20.
002-ASA 11-19-2014 05:29:44 %ASA-3-752015: Tunnel Manager has failed to establish an L2L SA. All configured IKE versions failed to establish the tunnel. Map Tag= outside_map. Map Sequence Number = 20.
002-ASA 11-19-2014 05:29:43 %ASA-4-752012: IKEv1 was unsuccessful at setting up a tunnel. Map Tag = outside_map. Map Sequence Number = 20.
002-ASA 11-19-2014 05:29:36 %ASA-4-713903: IP = 001.001.001.001, Information Exchange processing failed
002-ASA 11-19-2014 05:29:36 %ASA-5-713904: IP = 001.001.001.001, Received an un-encrypted INVALID_COOKIE notify message, dropping
001-ASA 11-19-2014 05:29:36 %ASA-4-713903: IP = 002.002.002.002, Header invalid, missing SA payload! (next payload = 4)
002-ASA 11-19-2014 05:29:26 %ASA-5-713904: IP = 001.001.001.001, Received an un-encrypted INVALID_COOKIE notify message, dropping
002-ASA 11-19-2014 05:29:26 %ASA-4-713903: IP = 001.001.001.001, Information Exchange processing failed
001-ASA 11-19-2014 05:29:26 %ASA-4-713903: IP = 002.002.002.002, Header invalid, missing SA payload! (next payload = 4)
001-ASA 11-19-2014 05:29:24 %ASA-5-713041: IP = 003.003.003.003, IKE Initiator: New Phase 1, Intf inside, IKE Peer 003.003.003.003 local Proxy Address 192.168.52.0, remote Proxy Address 192.168.13.32, Crypto map (outside_map)
001-ASA 11-19-2014 05:29:24 %ASA-4-752010: IKEv2 Doesn't have a proposal specified
001-ASA 11-19-2014 05:29:24 %ASA-5-752004: Tunnel Manager dispatching a KEY_ACQUIRE message to IKEv1. Map Tag = outside_map. Map Sequence Number = 20.
002-ASA 11-19-2014 05:29:18 %ASA-4-713903: IP = 001.001.001.001, Information Exchange processing failed
002-ASA 11-19-2014 05:29:18 %ASA-5-713904: IP = 001.001.001.001, Received an un-encrypted INVALID_COOKIE notify message, dropping
001-ASA 11-19-2014 05:29:18 %ASA-4-713903: IP = 002.002.002.002, Header invalid, missing SA payload! (next payload = 4)
001-ASA 11-19-2014 05:29:13 %ASA-3-752015: Tunnel Manager has failed to establish an L2L SA. All configured IKE versions failed to establish the tunnel. Map Tag= outside_map. Map Sequence Number = 20.
001-ASA 11-19-2014 05:29:13 %ASA-4-752012: IKEv1 was unsuccessful at setting up a tunnel. Map Tag = outside_map. Map Sequence Number = 20.
001-ASA 11-19-2014 05:29:10 %ASA-4-713903: Group = 002.002.002.002, IP = 002.002.002.002, Can't find a valid tunnel group, aborting...!
002-ASA 11-19-2014 05:29:10 %ASA-5-713041: IP = 001.001.001.001, IKE Initiator: New Phase 1, Intf inside, IKE Peer 001.001.001.001 local Proxy Address 192.168.13.32, remote Proxy Address 192.168.52.0, Crypto map (outside_map)
002-ASA 11-19-2014 05:29:10 %ASA-4-752010: IKEv2 Doesn't have a proposal specified
002-ASA 11-19-2014 05:29:10 %ASA-5-752004: Tunnel Manager dispatching a KEY_ACQUIRE message to IKEv1. Map Tag = outside_map. Map Sequence Number = 20.
002-ASA 11-19-2014 05:29:02 %ASA-3-752015: Tunnel Manager has failed to establish an L2L SA. All configured IKE versions failed to establish the tunnel. Map Tag= outside_map. Map Sequence Number = 20.
002-ASA 11-19-2014 05:29:02 %ASA-4-752012: IKEv1 was unsuccessful at setting up a tunnel. Map Tag = outside_map. Map Sequence Number = 20.
002-ASA 11-19-2014 05:28:54 %ASA-4-713903: IP = 001.001.001.001, Information Exchange processing failed
002-ASA 11-19-2014 05:28:54 %ASA-5-713904: IP = 001.001.001.001, Received an un-encrypted INVALID_COOKIE notify message, dropping
001-ASA 11-19-2014 05:28:54 %ASA-4-713903: IP = 002.002.002.002, Header invalid, missing SA payload! (next payload = 4)
002-ASA 11-19-2014 05:28:46 %ASA-4-713903: IP = 001.001.001.001, Information Exchange processing failed
002-ASA 11-19-2014 05:28:46 %ASA-5-713904: IP = 001.001.001.001, Received an un-encrypted INVALID_COOKIE notify message, dropping
001-ASA 11-19-2014 05:28:46 %ASA-4-713903: IP = 002.002.002.002, Header invalid, missing SA payload! (next payload = 4)
001-ASA 11-19-2014 05:28:41 %ASA-5-713041: IP = 003.003.003.003, IKE Initiator: New Phase 1, Intf inside, IKE Peer 003.003.003.003 local Proxy Address 192.168.52.0, remote Proxy Address 192.168.13.32, Crypto map (outside_map)
001-ASA 11-19-2014 05:28:41 %ASA-4-752010: IKEv2 Doesn't have a proposal specified
001-ASA 11-19-2014 05:28:41 %ASA-5-752004: Tunnel Manager dispatching a KEY_ACQUIRE message to IKEv1. Map Tag = outside_map. Map Sequence Number = 20.
002-ASA 11-19-2014 05:28:38 %ASA-4-713903: IP = 001.001.001.001, Information Exchange processing failed
002-ASA 11-19-2014 05:28:38 %ASA-5-713904: IP = 001.001.001.001, Received an un-encrypted INVALID_COOKIE notify message, dropping
001-ASA 11-19-2014 05:28:38 %ASA-4-713903: IP = 002.002.002.002, Header invalid, missing SA payload! (next payload = 4)
001-ASA 11-19-2014 05:28:31 %ASA-3-752015: Tunnel Manager has failed to establish an L2L SA. All configured IKE versions failed to establish the tunnel. Map Tag= outside_map. Map Sequence Number = 20.
001-ASA 11-19-2014 05:28:31 %ASA-4-752012: IKEv1 was unsuccessful at setting up a tunnel. Map Tag = outside_map. Map Sequence Number = 20.
001-ASA 11-19-2014 05:28:31 %ASA-4-713903: Group = 002.002.002.002, IP = 002.002.002.002, Can't find a valid tunnel group, aborting...!
002-ASA 11-19-2014 05:28:31 %ASA-5-752004: Tunnel Manager dispatching a KEY_ACQUIRE message to IKEv1. Map Tag = outside_map. Map Sequence Number = 20.
002-ASA 11-19-2014 05:28:31 %ASA-4-752010: IKEv2 Doesn't have a proposal specified
002-ASA 11-19-2014 05:28:31 %ASA-5-713041: IP = 001.001.001.001, IKE Initiator: New Phase 1, Intf inside, IKE Peer 001.001.001.001 local Proxy Address 192.168.13.32, remote Proxy Address 192.168.52.0, Crypto map (outside_map)
002-ASA 11-19-2014 05:28:23 %ASA-3-752015: Tunnel Manager has failed to establish an L2L SA. All configured IKE versions failed to establish the tunnel. Map Tag= outside_map. Map Sequence Number = 20.
002-ASA 11-19-2014 05:28:23 %ASA-4-752012: IKEv1 was unsuccessful at setting up a tunnel. Map Tag = outside_map. Map Sequence Number = 20.
002-ASA 11-19-2014 05:28:14 %ASA-4-713903: IP = 001.001.001.001, Information Exchange processing failed
002-ASA 11-19-2014 05:28:14 %ASA-5-713904: IP = 001.001.001.001, Received an un-encrypted INVALID_COOKIE notify message, dropping
001-ASA 11-19-2014 05:28:14 %ASA-4-713903: IP = 002.002.002.002, Header invalid, missing SA payload! (next payload = 4)
002-ASA 11-19-2014 05:28:06 %ASA-4-713903: IP = 001.001.001.001, Information Exchange processing failed
002-ASA 11-19-2014 05:28:06 %ASA-5-713904: IP = 001.001.001.001, Received an un-encrypted INVALID_COOKIE notify message, dropping
001-ASA 11-19-2014 05:28:06 %ASA-4-713903: IP = 002.002.002.002, Header invalid, missing SA payload! (next payload = 4)
001-ASA 11-19-2014 05:27:59 %ASA-5-713041: IP = 003.003.003.003, IKE Initiator: New Phase 1, Intf inside, IKE Peer 003.003.003.003 local Proxy Address 192.168.52.0, remote Proxy Address 192.168.13.32, Crypto map (outside_map)
001-ASA 11-19-2014 05:27:59 %ASA-4-752010: IKEv2 Doesn't have a proposal specified
001-ASA 11-19-2014 05:27:59 %ASA-5-752004: Tunnel Manager dispatching a KEY_ACQUIRE message to IKEv1. Map Tag = outside_map. Map Sequence Number = 20.
002-ASA 11-19-2014 05:27:58 %ASA-4-713903: IP = 001.001.001.001, Information Exchange processing failed
002-ASA 11-19-2014 05:27:58 %ASA-5-713904: IP = 001.001.001.001, Received an un-encrypted INVALID_COOKIE notify message, dropping
001-ASA 11-19-2014 05:27:58 %ASA-4-713903: IP = 002.002.002.002, Header invalid, missing SA payload! (next payload = 4)
001-ASA 11-19-2014 05:27:54 %ASA-3-752015: Tunnel Manager has failed to establish an L2L SA. All configured IKE versions failed to establish the tunnel. Map Tag= outside_map. Map Sequence Number = 20.
001-ASA 11-19-2014 05:27:54 %ASA-4-752012: IKEv1 was unsuccessful at setting up a tunnel. Map Tag = outside_map. Map Sequence Number = 20.
001-ASA 11-19-2014 05:27:50 %ASA-4-713903: Group = 002.002.002.002, IP = 002.002.002.002, Can't find a valid tunnel group, aborting...!
002-ASA 11-19-2014 05:27:50 %ASA-5-713041: IP = 001.001.001.001, IKE Initiator: New Phase 1, Intf inside, IKE Peer 001.001.001.001 local Proxy Address 192.168.13.32, remote Proxy Address 192.168.52.0, Crypto map (outside_map)
002-ASA 11-19-2014 05:27:50 %ASA-4-752010: IKEv2 Doesn't have a proposal specified
002-ASA 11-19-2014 05:27:50 %ASA-5-752004: Tunnel Manager dispatching a KEY_ACQUIRE message to IKEv1. Map Tag = outside_map. Map Sequence Number = 20.
002-ASA 11-19-2014 05:27:42 %ASA-3-752015: Tunnel Manager has failed to establish an L2L SA. All configured IKE versions failed to establish the tunnel. Map Tag= outside_map. Map Sequence Number = 20.
002-ASA 11-19-2014 05:27:42 %ASA-4-752012: IKEv1 was unsuccessful at setting up a tunnel. Map Tag = outside_map. Map Sequence Number = 20.
002-ASA 11-19-2014 05:27:34 %ASA-4-713903: IP = 001.001.001.001, Information Exchange processing failed
002-ASA 11-19-2014 05:27:34 %ASA-5-713904: IP = 001.001.001.001, Received an un-encrypted INVALID_COOKIE notify message, dropping
001-ASA 11-19-2014 05:27:34 %ASA-4-713903: IP = 002.002.002.002, Header invalid, missing SA payload! (next payload = 4)
002-ASA 11-19-2014 05:27:26 %ASA-4-713903: IP = 001.001.001.001, Information Exchange processing failed
002-ASA 11-19-2014 05:27:26 %ASA-5-713904: IP = 001.001.001.001, Received an un-encrypted INVALID_COOKIE notify message, dropping
001-ASA 11-19-2014 05:27:26 %ASA-4-713903: IP = 002.002.002.002, Header invalid, missing SA payload! (next payload = 4)
001-ASA 11-19-2014 05:27:22 %ASA-5-713041: IP = 003.003.003.003, IKE Initiator: New Phase 1, Intf inside, IKE Peer 003.003.003.003 local Proxy Address 192.168.52.0, remote Proxy Address 192.168.13.32, Crypto map (outside_map)
001-ASA 11-19-2014 05:27:22 %ASA-4-752010: IKEv2 Doesn't have a proposal specified
001-ASA 11-19-2014 05:27:22 %ASA-5-752004: Tunnel Manager dispatching a KEY_ACQUIRE message to IKEv1. Map Tag = outside_map. Map Sequence Number = 20.
11-19-2014 08:49 PM
Hello Jason,
According to this logs, the crypto map with sequence number 20 is havng issues to establish the site to site IPsec, so they indicate phase 1 is not completed yet.
Usually this is an issue with the encryption algorithms defined, and also issues in the middle <ISP>.
This should not affect the performance of your ASA, or routing on your ASA.
You can confirm with --> show crypto isakmp sa
To see if the tunnel can establish phase 1.
If you have another question let me know,
Please don´t forget to rate the helpful Post!
David Castro,
