Logging Issue
aneesh.ts
Level 3
Level 3
Am always receiving up logs in one of my LAN interfaces. There are n
o interface downlods.
Wondering what could be the issue. Could there be a real link flap issue.
Why could the same link always come up without going down.
001391: Jun  4 09:51:58.850 INDIA: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
001392: Jun  4 12:01:19.930 INDIA: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
001393: Jun  4 12:01:25.438 INDIA: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
001394: Jun  4 12:02:43.599 INDIA: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
Any suggestions?
Thanks in advance.
AneesH
This could be CSCsv90092.  Is CEF disabled?  If so, enabling on this interface will work around the problem.  The bug is fixed in 12.4(15)T10.
Joe Clarke
What version of code is running on this device?
IOS & hardware details..
Cisco IOS Software, 1841 Software (C1841-IPBASE-M), Version 12.4(15)T9, RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2009 by Cisco Systems, Inc.
Compiled Tue 28-Apr-09 11:11 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
NS-CHN-DLN-R01-P uptime is 16 weeks, 6 days, 4 hours, 20 minutes
System restarted at 09:57:22 TOKYO Tue Feb 9 2010
System image file is "flash:c1841-ipbase-mz.124-15.T9.bin"
Cisco 1841 (revision 7.0) with 115712K/15360K bytes of memory.
Processor board ID FHK1327736Z
2 FastEthernet interfaces
1 Serial(sync/async) interface
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
31360K bytes of ATA CompactFlash (Read/Write)
AneesH
Hi joe,
Thank you so much mate.
You were absolutely right. We've seen a lot of throttles as mentioned in the Bug description.
Unfortunately CEF is already enabled on the router. However I again enabled it on the interface.
Not sure whether it will help.
Lemme monitor the device for a while now. Since its not impacting, nothing much to worry.
You were so helpful and I totally appreciate your effort with this.
AneesH
