Logging statements
vnealy
Community Member
Does anyone know if the logging statements are needed in order for Ciscoworks to recieve traps?
Thanks.
nhabib
Level 11
Level 11
If you are referring to syslog messages, then yes.
If you are referring to snmp traps, then the logging command is of no use. CiscoWorks does not do much with SNMP traps though, so you want to make sure you are sending syslog messages to CiscoWorks.
vnealy
Community Member
Thank you.
vnealy
Community Member
Excuse me but what piece in CW uses syslog? DFM?
Thanks.
RME uses Syslog
DFM has very limited SNMP trap processing:
http://www.cisco.com/univercd/cc/td/doc/product/rtrmgmt/cw2000/dfm/dfm_faq.htm
