Low bandwidth alert
duncanm
We get hit with indirect link failures that we have to rely on Cacti to show. Sadly, it can take our NOC guys hours to detect. I'm thinking a TCL script that watches ifHCInOctets (.1.3.6.1.2.1.31.1.1.1.6) and ifHCOutOctets (1.3.6.1.2.1.31.1.1.1.10) and if either hits 0 to send an alert. Is this doable? Or is there a better way?
Joe Clarke
I assume you mean if either of those OIDs do not increment for a specific period of time?  If so, then yes.  You can do this with an EEM applet:
event manager applet monitor-bandwidth
event tag e1 snmp oid 1.3.6.1.2.1.31.1.1.1.6.1 get-type exact entry-op eq entry-val 0 entry-type increment poll-interval 60
event tag e2 snmp oid 1.3.6.1.2.1.31.1.1.1.10.1 get-type exact entry-op eq entry-val 0 entry-type increment poll-interval 60
trigger
  correlate event e1 or event e2
action 1.0 syslog msg "Input or output octets was zero for the past 60 seconds for GigabitEthernet0/0"
This applet assumes GigabitEthernet0/0 has an ifIndex of 1.
The PRTG PAESSLER do that without burn the eyelashes in a code,
