LSM 2.6 how to stop SysInvPoller
I integrate LSM with ACS, and I got the error with SysInvPoller, because the older owner has no rights to run this command. So I did a new job.
The new job work great, but I cannot find a way to stop the old SysInvPoller.
Some of you has any experience or idea ?
Thank you really much.
Best regards Antonello.
yjdabear
Hmmm, if you know the number of the old SysInvPoller job, I wonder if you could delete throuth "jobcli":
http://www.cisco.com/en/US/docs/net_mgmt/ciscoworks_resource_manager_essentials/4.0.3/release/notes/rnsol403.html
Duplicate entries may appears for system RME inventory jobs, when the you try to change the job schedule.
Workaround:
Use the job CLI to delete any unwanted jobs.
1. Enter these commands:
cd /opt/CSCOpx/bin
cwjava -cw /opt/CSCOpx com.cisco.nm.cmf.jrm.jobcli delete unwanted_job_id
(where unwanted_job_id is the ID of the job you want to delete.)
2. Then restart the daemons using these commands:
/etc/init.d/dmgtd stop
/etc/init.d/dmgtd start
